component -----"micrium_uc_osii" problem
Hi,everyone.
In niosII 1.0's revision,It provide micrium_uc_osii component and some software temples of uc/osII and lwip .But in niosII 1.1,haven't micrium_uc_osii component and such temples.Why?micrium_uc_osii don't exist in NiosII 1.1? Thank you very much? I am working for uc_osii and lwip? But meet with many problems.Can someone give me some advice or temples.6 Replies
Hi zzh,
it happens to me too when i got the evaluation version of NiosII 1.1, i don't know if it's your situation... - Altera_Forum
MicroC/OS-II is the 1.1 kit, though not in the eval version.
Thank you for your reply.Soin,I think we met the same problem.
Hi,rugbybloke.How can I get the complete version.If I can't get this version,how can I study uc/osII and lwip. Please give me some advice. - Altera_Forum
uC/OS-II comes with the full version of Nios II. Since you said 'study' I assume you are a student. If you are a student, I recommend you and your professor check out Altera's university program (you might be able to get a full version that way). With the full version not only do you get uC/OS-II but you also don't need to leave a JTAG cable connected to your hardware like you do in the evaluation version.
If you purchased a Nios Development Board you should have a full license already. (So I would check out Altera's licensing to see what would be best for you). - Altera_Forum
Another option would be to go with the standalone version of LWIP, available on this forum. It ships with a working web server and C array based "filesystem". It's not updated to 5.0....yet, however.
- slacker - Altera_Forum
Thank you BadOme.
my lab purchased altera's stratix1s10 develop board and get niosii 1.0. after i installed 1.0, in the componenet directory there isn't ".project" file .so when i open niosii ide there isn't niosii drivers project . and i run hello_ucosii project ,it can't work too.i don't why ,the instance can't run. i remember it can run before but it can't now . it is different after i install the ide yes,I am a student . I like this very much, but I have so many problems .Thank you .
