21 years agoCompiler Setting in NIOSII IDE
I am looking for a compiler setting to create an assembler output file from C-source. I didn't found this topic in the GNU-Compiler discribtion. I always like to have a closer look at the compiled code. Thanks for help3 Replies
If you type nios2-elf-gcc --help in a Nios II SDK Shell window that will give you the options
The option -S Compile only; do not assemble or link sounds like what you're after - Altera_Forum
I tried the option -c "compile and assemble but do not link" in NIOS II IDE. That doesn't work.
I changed the C/C++ build properties , compiler flags = -c See the following screenshot : make -s all Compiling MAIN.c... Compiling alt_irq_register.c... Compiling alt_main.c... Linking IRQ_CHECK.elf... nios2-elf-g++: cannot specify -o with -c or -S and multiple compilations make: *** [IRQ_CHECK.elf] Error 1 Build completed I really don't think that option : S Compile only; do not assemble or link is the rigth one - I'd like to see whats the assembled output of my C-source. I think it is even a problem to change this under NIOS IDE II ? Thank for help. - Altera_Forum
ots_dev,
The __gcc__ option "-S" is correct (that's uppercase 'S'). With this option gcc stops after compiling and the output is an assembler file. When you use "-s" (lowercase) as a __make__ option, you're telling make to run in silent mode. You can always use objdump to view the actual object file as well with the -D option : nios2-elf-objdump -D foo.o Regards, --Scott
