21 years agoCompiler Setting in NIOSII IDE
Hi, I am looking for a compiler setting to create an assembler output file from C-source. I didn't found this topic in the GNU-Compiler discribtion. I always like to have a closer look at ...
21 years agoI tried the option -c "compile and assemble but do not link" in NIOS II IDE. That doesn't work.
I changed the C/C++ build properties , compiler flags = -c See the following screenshot : make -s all Compiling MAIN.c... Compiling alt_irq_register.c... Compiling alt_main.c... Linking IRQ_CHECK.elf... nios2-elf-g++: cannot specify -o with -c or -S and multiple compilations make: *** [IRQ_CHECK.elf] Error 1 Build completed I really don't think that option : S Compile only; do not assemble or link is the rigth one - I'd like to see whats the assembled output of my C-source. I think it is even a problem to change this under NIOS IDE II ? Thank for help.
