13 years agoCompile the AppWeb Webserver
Hey,
i'm actually trying to compile and run the AppWeb Webserver with the uClinux distribution and the ArriaGX II Dev Kit. I followed some Guides in the Altera Wiki to compile the uClinux and successfully run it on the ArriaGX II. Then I customized the Application and Library Settings and added the AppWeb Webserver. But now the make process ends with the following error:make: Betrete Verzeichnis '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb'
make.dep:12: config.make: Datei oder Verzeichnis nicht gefunden
make: *** Keine Regel vorhanden, um das Target »conf/make.os.«,
benötigt von »make.os«, zu erstellen. Schluss.
make: Verlasse Verzeichnis '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb' translation: make: enter directory '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb'
make.dep:12: config.make: file or directory not found
make: *** No rule available to make target »conf/make.os.«,
used by »make.os«. end.
make: leave directory '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb' I also tried to compile the AppWeb separately. The build process was successful but if i try to start the AppWeb the following error occurs: root:/bin/appweb/bin> ./appweb start
sh: syntax error: unexpected $ I'm really at a loss with this. Can anyone help me? greetings Bergmann89. Wiki Links: alterawiki.com/wiki/UClinux alterawiki.com/wiki/InstallNios2Linux3 Replies
--- Quote Start --- I also tried to compile the AppWeb separately. The build process was successful but if i try to start the AppWeb the following error occurs:
I'm really at a loss with this. --- Quote End --- My guess is that appweb is a shell script that expects the shell to be bash, and you're using sash or hush.root:/bin/appweb/bin> ./appweb start sh: syntax error: unexpected $ - Altera_Forum
the uClinux comes with busybox. I'm not sure, but i think it uses 'hush'. I found another guide, which i tried: appwebserver.org/products/appweb/doc.2/guide/appweb/source/packages.html but it ends with the same error as above. There must be any way, to get it work... greetings Bergmann. - Altera_Forum
Hello community,
I'm also trying to compile the *altera-delivered* "appWeb". After some adjustments (thanks to ykozlov for pointing to the right direction) I'm running into the same error like Bergmann89 did:
Looking into the according Makefile under "...\appWeb\mpr\UNIX\" and regarding the above error message I assume that the Makefile has not been implemented. Due to I don't have much knowledge about this whole Makefile-stuff it's very frustrating at this point. Is there anybody out there who can give some advice or even better provide a correct Makefile for this app? I think this server-app is a very cool tool to provide dynamic webpages, using server-side JavaScript and PHP on uClinux. Thanks in advance for any help! Cheers! guineamake: enter directory '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb' make.dep:12: config.make: file or directory not found make: *** No rule available to make target »conf/make.os.«, used by »make.os«. end. make: leave directory '/home/nios/Projects/nios2-linux/uClinux-dist/user/appWeb'
