13 years agoCompile the AppWeb Webserver
Hey, i'm actually trying to compile and run the AppWeb Webserver with the uClinux distribution and the ArriaGX II Dev Kit. I followed some Guides in the Altera Wiki to compile the uClinux and s...
13 years ago --- Quote Start --- I also tried to compile the AppWeb separately. The build process was successful but if i try to start the AppWeb the following error occurs:
root:/bin/appweb/bin> ./appweb start
sh: syntax error: unexpected $ I'm really at a loss with this. --- Quote End --- My guess is that appweb is a shell script that expects the shell to be bash, and you're using sash or hush.
