12 years agoCompile Failed with recursively call by uclinux project
I got some problem of porting uclinux on de2-115 board. Top level entity name is uclinux.v i tried to compiling project, and have error. here is code,module uclinux( CLOCK_50,
UART_RXD,
UART_TXD,
DRAM_WE_N,
DRAM_RAS_N,
DRAM_CS_N,
DRAM_CLK,
DRAM_CKE,
DRAM_CAS_N,
DRAM_DQM,
DRAM_DQ,
DRAM_BA,
DRAM_ADDR
input CLOCK_50;
input UART_RXD;
output UART_TXD;
output DRAM_CAS_N;
output DRAM_CS_N;
output DRAM_CKE;
output DRAM_WE_N;
output DRAM_ADDR;
output DRAM_RAS_N;
output DRAM_DQM;
output DRAM_DQ;
output DRAM_BA;
output DRAM_CLK;
wire sys_clk;
uclinux uc (
.clk_clk (sys_clk),
.reset_reset_n (1),
.sdram_wire_addr (DRAM_ADDR),
.sdram_wire_ba (DRAM_BA),
.sdram_wire_cas_n (DRAM_CAS_N),
.sdram_wire_cke (DRAM_CKE),
.sdram_wire_cs_n (DRAM_CS_N),
.sdram_wire_dq (DRAM_DQ),
.sdram_wire_dqm (DRAM_DQM),
.sdram_wire_ras_n (DRAM_RAS_N),
.sdram_wire_we_n (DRAM_WE_N),
.uart_external_connection_rxd (UART_RXD),
.uart_external_connection_txd (UART_TXD)
pllnios n0 (
.inclk0(CLOCK_50),
.c0(sys_clk),
.c1(DRAM_CLK)
endmodule
and with this error message,
Info (12127): Elaborating entity "uclinux" for the top level hierarchy
Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0"
Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0"
Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0|uclinux:u0"
Info (12128): Elaborating entity "uclinux" for hierarchy "uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0|uclinux:u0"
Error (12051): Project too complex: hierarchy path is too long
Error (12052): Entity "uclinux" is instantiated by entity "uclinux" why cause recursively call to 'uclinux' module in this project?4 Replies
You are recusivelly instantiating module inside a module because the top module has the same name as QSys module. I would suggest you change one of them.
Thanks to You're suggestion, But I think this problem caused by 'uclinux:u0 ' macro function.
I already tried change from 'uclinux u0' to 'uclinux uc'. And then, I got same error message again. So, What could i do solve this problem? - Altera_Forum
If the top module is named uclinux there should be no modules named uclinux in it. I would suggest you either change qsys name or top level name.
Also, this is a Verilog question and it should be in different forum. - Altera_Forum
Oh, I'm really appriciate your help.
I changed macro name from 'uclinux' to 'niosqsys', and successfully compile it. Thank you janco.
