12 years agoCompile Failed with recursively call by uclinux project
Hi, I got some problem of porting uclinux on de2-115 board. Top level entity name is uclinux.v i tried to compiling project, and have error. here is code, module uclinux( C...
12 years agoIf the top module is named uclinux there should be no modules named uclinux in it. I would suggest you either change qsys name or top level name.
Also, this is a Verilog question and it should be in different forum.
