21 years agoCommunication with JTAG Uart
Hi all,
The (host) application I'm writing needs to communicate thru JTAG with our target board. I know that nios2-terminal tool can start a terminal session with our target board. But how can I do it with my own application? Do I need some kind of DLL? Documentations ???? Hope someone can help. Regards, Kwok Wong4 Replies
nios2-terminal.exe imports cygwin1.dll and jtag_atlantic.dll, which in turn imports jtag_client.dll
I'd like to know as well, as it could be really useful. Is the source code for nios2-terminal available? - Altera_Forum
--- Quote Start --- originally posted by jasondiplomat@Jun 29 2005, 11:12 AM nios2-terminal.exe imports cygwin1.dll and jtag_atlantic.dll[/b], which in turn imports jtag_client.dll I'd like to know as well, as it could be really useful. Is the source code for nios2-terminal available?[/b] --- Quote End --- I figure out a laborious workaround: 1. Put any thing to be sent in a file (e.g. send.dat) 2. Start nios2-terminal as folllows: cat send.dat | nios2-terminal --cable 2 > receive.dat The file receive.dat will contain data sent by the target board. Definitely this is NOT the solution to our problem. So I do hope other experts / Altera tech support people can help! Regards, Kwok Wong (The Netherlands) - Altera_Forum
--- Quote Start --- originally posted by kwokwong2+jun 30 2005, 04:49 am--><div class='quotetop'>quote (kwokwong2 @ jun 30 2005, 04:49 am)</div>--- quote start ---
<!--quotebegin-jasondiplomat@Jun 29 2005, 11:12 AM nios2-terminal.exe imports cygwin1.dll and jtag_atlantic.dll[/b], which in turn imports jtag_client.dll I'd like to know as well, as it could be really useful. Is the source code for nios2-terminal available?[/b] --- Quote End --- I figure out a laborious workaround: 1. Put any thing to be sent in a file (e.g. send.dat) 2. Start nios2-terminal as folllows: cat send.dat | nios2-terminal --cable 2 > receive.dat The file receive.dat will contain data sent by the target board. Definitely this is NOT the solution to our problem. So I do hope other experts / Altera tech support people can help! Regards, Kwok Wong (The Netherlands) [/b] --- Quote End --- Info about the jtag server is also welcome!
TO_BE_DONE
