16 years ago
Changing the Size of Data and Instruction Cache
Hello again,
I am trying to increase the data and instruction cache to test if the speed increases when reading data from the UART. At first, I tried making it four times bigger, Quartus said it couldn't fit into the device, so I eliminated the VGA and Audio modules in SOPC (I am not using them). After that I increased Instruction Cache to 8 KBytes, and Data Cache to 4 KBytes, which is the double of what I had by default.
Quartus compiles the project succesfully, and everything is loaded into the FPGA. However, when I open nios2-terminal it never boots correctly, It just freezes after "Uncompressing Linux........ok, booting the kernel" And then nothing happens. I don't know if I should change something in the kernel or app config. Because I've tried so far with different combinations of Data and Instruction Cache sizes, but none of them boots correctly, except for the default values (4K Instruction and 2K data).
Does the Operating System register automatically the size of the cache for both instruction and data? I haven't modified the Cache Line Size, it is still in 4 Bytes.
Does it have anything to do with the Quartus License? I don't think so..
Any configuration trick on Make Menuconfig?
I thought this would be a trivial modification but it turns out it isn't... perhaps I overlooked something but not sure. To be honest, I had never changed the size of these memories.
Any ideas on this please? :S
Francisco
    Hello again lads,
    So I started the system from scratch. I did "git clean -f -x -d" and lost all changes. First I compiled the quartus project including the larger cache memories (8Inst and 4Data), then started from make menuconfig with default options.
    then make vendor_hw select
    make romfs
    make
    nios2-configure sof
    nios2-download -g
    nois2-terminal
    the results, the same :( below is a message of where it stops most frequently.
    NiosII EDS]$ nios2-terminal
    nios2-terminal: connected to hardware target using JTAG UART on cable
    nios2-terminal: "USB-Blaster ", device 1, instance 0
    nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
    Uncompressing Linux... Ok, booting the kernel.
    Linux version 2.6.30 (pancho@holaamigos) (gcc version 3.4.6)# 5 PREEMPT Tue Jul 14 20:19:15 CDT 2009
    uClinux/Nios II
    Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 2032
    Kernel command line:
    NR_IRQS:32
    PID hash table entries: 32 (order: 5, 128 bytes)
    Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Memory available: 5352k/2556k RAM, 0k/0k ROM (1669k kernel code, 887k data)
    Calibrating delay loop... 46.48 BogoMIPS (lpj=232448)
    Mount-cache hash table entries: 512
    net_namespace: 264 bytes
    NET: Registered protocol family 16
    init_BSP(): registering device resources
    bio: create slab <bio-0> at 0
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 512 (order: 0, 4096 bytes)
    TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    TCP: Hash tables configured (established 512 bind 512)
    TCP reno registered
    io scheduler noop registered
    io scheduler deadline registered (default)
    ttyJ0 at MMIO 0x19020f0 (irq = 2) is a Altera JTAG UART
    console  enabled
    ttyS0 at MMIO 0x1902040 (irq = 3) is a Altera UART
    dm9000 Ethernet Driver, V1.31
    Exactly the same line as before. NOw I&#39;ve got to build again all the drivers. Good thing I worte them down hehe.
    Still haven&#39;t been able. Any ideas are welcome.
    Thank you all
    Francisco
    Hello Friends,
    I have managed to run the system with the configuration I sent you. This is with 8K Instruction Cache and 2K Data Cache. This configuration is one step below what I actually need. I am trying to run the system with 16K Instruction Cache and 2K Data Cache. Do you think it is possible? I only modified this parameter in SOPC Builder for the Nios II cpu.
    I have already compiled the project with these characteristics and it says everything's fine. However, I am still having the same problem. The OS (uClinux) does not boot correctly.
    Is there a relation that must be maintained between the sizes of data and instruction cache?
    Is this within the DE2 Board capabilities?
    I have a DE2-70 Board which I could use if a bigger device is needed.
    Thank you
    FRancisco
