17 years ago
CFI FLASH access from Nios IDE
Good afternoon.
Unfortunatelly, i didn't find the solving of the problem with CFI Flash, so i decided to create a new thread.
I have Cycolne III Dev Kit and flash on the board and want to make access to flash through the CFI.
i have added the CFI Flash and Tri-state Bridge to my project. then made pins in the quartus and try make access to the flash.
At last i could get the CFI table from the Nios Command Shell through the nios2-flash-programmer and today i have succefully wrote data to the flash and read it from flash.
But i can't do the same in the Nios II IDE. The result of function alt_flash_open_dev(CFI_FLASH_NAME); is zero - so the device doesn't open.
The options in system library included all wrivers and the CFI i thnk so too...
Are there any ideas why it doesn't work?
    I had the same problem 3 weeks ago.
    The CFI flash is a 16-bit addressable device. I guess you have it wired up as if it was 8-bit addressable.
    Connect bit 1 of the NIOS address to bit 0 of the CFI device in your Verilog
    eg
    flash_padd[22..0] = nios_mod.address_to_the_cfi_flash[23..1];
    flash_padd[23] = clr;
    hope that helps ...
    Bruce
    Thank you very much.
    I've already successfully done the cfi flash.
    You are right, we should connect Nios [1] to pin flash[0].
    Besides we shouldn't mark option "reduced device drivers" or the drivers for the Flash won't be included.
    Today i tried to start the nios software from the CFI Flash and it works.
    if anybody have questions about the CFI Flash with Nios I'll try to answer it =)
    Unfortunatelly i have another problem: i can't get access to the flash from nios ide in the example of simple socket server (SSS), but i can see the cfi table from command shell of nios ide. I didn't check the small с library or reduced drivers in system library.
    But when i start the example of hello world - i can access flash from nios ide but a have the same settings of system library as for the SSS =(
    Are there any ideas about this case?
    Hello to everybody.
    I made my flash workable, but now I have a question.
    I have a special board with Cyclone III, not dev kit.
    There is no Max II.
    So I want to program my flash with Nios software to store there my cpu code.
    How can i programm it?
    There is a parallel flash loader, but it can load only pof files (sof i can convert to pof). And what about the *.flash type?
    Maybe there is a converter such as sof2flash, but flash2sof?
