17 years agoCFI FLASH access from Nios IDE
Good afternoon. Unfortunatelly, i didn't find the solving of the problem with CFI Flash, so i decided to create a new thread. I have Cycolne III Dev Kit and flash on the board and want to...
16 years agoUnfortunatelly i have another problem: i can't get access to the flash from nios ide in the example of simple socket server (SSS), but i can see the cfi table from command shell of nios ide. I didn't check the small с library or reduced drivers in system library.
But when i start the example of hello world - i can access flash from nios ide but a have the same settings of system library as for the SSS =( Are there any ideas about this case?
