cfi flash : code error 8 from nios2 flash programmer
Info: Mar 28, 2013 12:52:59 PM - (INFO) elf2flash: args = --input=E:/PCIE/NOR_FLASH/software/Hello/Hello.elf --output=E:/PCIE/NOR_FLASH/software/Hello_bsp/flash/Hello_cfi_flash_0.flash --boot=C:/altera/12.0/nios2eds/components/altera_nios2/boot_loader_cfi.srec --base=0x10000000 --end=0x20000000 --reset=0x10000000 --verbose
Info: Mar 28, 2013 12:52:59 PM - (FINE) elf2flash: Starting
Info: Mar 28, 2013 12:52:59 PM - (FINE) elf2flash: Done
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x20005008: verified
Info: no cfi table found at address 0x10000000
Info: Original contents (after writing 0xF0 and 0xFF00FF to address 0x10000000):
Info: 0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: 40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
Info: Contents after writing 0x980098 to address 0x100000AA:
Info: Same after writing 0x980098 to address 0x10000154:
Info: Same after writing 0x00980098 to address 0x100002A8:
Info: Same after writing 0x980098 to address 0x10000055:
Info: Same after writing 0x980098 to address 0x100000AA:
Info: Same after writing 0x00980098 to address 0x10000154:
Info: Same after writing 0x980098 to address 0x100002A8:
Info: Same after writing 0x00980098 to address 0x10000550:
Info: 0: 89 00 01 00 89 00 04 00 04 D8 04 D8 04 D8 04 D8 ................
Info: 10: 51 00 59 00 00 00 01 00 00 00 00 00 20 00 95 00 Q.Y......... ...
Info: 20: 0A 00 00 00 02 00 00 00 01 00 0A 00 01 00 03 00 ................
Info: 30: 02 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF ................
Info: Ignored possible autoselect code 89-01 as no override data
Info: present in section [FLASH-89-01]
Info: Ignored possible autoselect code 0089-0001 as no override data
Info: present in section [FLASH-0089-0001]
Info: Ignored possible autoselect code 00010089-00040089 as no override data
Info: present in section [FLASH-00010089-00040089]
Info: leaving target processor paused
error: error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "E:/PCIE/NOR_FLASH/software/Hello_bsp/flash/Hello_cfi_flash_0.flash" --base=0x10000000 --sidp=0x20005008 --id=0x0 --timestamp=1364451186 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose
in this CFI Flash base address is automatically assigned in SOPC Builder, Reset Vector in Nios Processor is assigned to cfi_flash.
but when i tried to read from flash in c code by low level drivers
like IOWR and IORD cfi flash query missing at addres ox11 instead of 0x52 its showing again 0x51.
i am aso tried with flash over ride file its coming another error
device commands not compatible with the device size .
what can i do for this plz reply .
its been 10 days posted no one is giving reply
- EricMunYew_C_Intel
Can you attach your .qsys or block diagram ?
Can you check and refer to the attached.
- praveenkumar
yeah its the same way i designed in the qsys and also while i writing to flash by following the datasheet procedure .
ox4089 if i am writing this 16 bit data in some 0x0 location
and while i am reading the location 0x0 its showing 0x89 and 0x1 location its showing 0x40.
its showing lsb in 0x0 location and MSb in 0x1 location.
through code its reading some cfi table locations according to datasheet.
so i think i correctley designed in qsys. and none of the above problems are solved .
thaks for reply.
Have you tried to program your flash using Quartus Programmer and PFL.
You can refer to below for PFL IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
- praveenkumar
yeah that's working fine .
but i dont want that ,i converted sof file to .flash file and write it in ox20000 onwards by receiving the data in .flash file through uart but it is not booting on power on .
do we need to write other than converted sof file to boot up on power on .
do i need to convert pof file to hex file and write that data from 0x20000 onwards but pof file is having other data than .sof file do we need convert pof file and write to flash i want to know that data .
or any other suggestions . actually in all pdfs its mentioned we have to write from 0x20000 onwards
reply fastly man, i had no time left.
- praveenkumar
ACtually ,i connected tristate controller in qsys, and assigned pins in pin planner and i programmed through quartus programmer but it is not booting ,i tried all the methods given in handbook setting the reset vector ans exception and also bsp settings nothing worked out.
Without generic controller it is booting by initializing the onchip memory with the hex file .
our flash is micron rc256p33tfe flash in genric tristate controller i applied intel pcp30256flash but it is not boooting .
our booting method is active parallel. can i use tristate controller in active parallel .
thank u
You can refer to below.
The PFL allows fast passive parallel but not active parallel.
- praveenkumar
then what ip supports active parallel .
can u show the process for active parallel booting in cyclone iii fpga .
In cyclone iii fpga supports active parallel booting .i read it in the document .
help me with booting process for cyclone iii active parallel flash .
Yes Cyclone III supports active parallel. In active parallel, you can connect the DCLK from your Cyclone III to Micron flash.
- praveenkumar
in active parallel config we can access flash through tristate controller right.
or we have to use only pfl .
we can program through nios2flash programmer also .i had seen in document.
only through pfl it is flashing when we initialize the memory content with hex file .
otherwise it is not working through tristate controller and nios2flash programmer .
can u tell me why i want it through tristate controller otherwise its not going to suit my aplication.will u please reply quickly.
pfl for flashing and tristate controller for data read write.
- praveenkumar
if we rewrite the flashed program locations from ox20000 through tristate controller in same locations by flash file
upon power up ,program will run or not???
You can't change the FPGA image and program locations after flashed.
- praveenkumar
hi,
why cant i change the FPGA image and program locations after flashed, if i want to modify the program then there is no usb blaster after integration then i want to load the program through rs422 communication . how it is possible without modifying flash locations.
even if we load through jtag memory location contents will be changed.
please give me a solution for loading the program through uart-422 communication
