praveenkumar
5 years agocfi flash : code error 8 from nios2 flash programmer
hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCa
Intel
EricMunYew_C_Intel
5 years agoYes Cyclone III supports active parallel. In active parallel, you can connect the DCLK from your Cyclone III to Micron flash.
- praveenkumar5 years ago
in active parallel config we can access flash through tristate controller right.
or we have to use only pfl .
we can program through nios2flash programmer also .i had seen in document.
only through pfl it is flashing when we initialize the memory content with hex file .
otherwise it is not working through tristate controller and nios2flash programmer .
can u tell me why i want it through tristate controller otherwise its not going to suit my aplication.will u please reply quickly.
