11 years agoCan't compile tutorial: Introduction to the Altera Qsys System Integration Tool?
Hi all,
I'm using Quartus 15.0.2 and I'm trying to learn about Nios using this tutorial: ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/introduction_to_the_altera_qsys_tool.pdf I have a BeMicroMAX10. I followed all the way to number 6 where I have to compile the project but it fails with several errors. I haven't assigned any pins yet. Here are the errors I get... if anyone could point me in the right direction I'll be happy to read ... I just got lost now in the documentation. Thhanks. Info: ******************************************************************* Info: Running Quartus II 64-Bit Analysis & Synthesis Info: Version 15.0.2 Build 153 07/15/2015 SJ Web Edition Info: Processing started: Fri Aug 14 18:03:48 2015 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off BeMicroMAX10_RodoNios -c BeMicroMAX10_RodoNios Info (11104): Parallel Compilation has detected 8 hyper-threaded processors. However, the extra hyper-threaded processors will not be used by default. Parallel Compilation will use 4 of the 4 physical processors detected instead. Info (12021): Found 1 design units, including 1 entities, in source file bemicromax10_rodonios.v Info (12023): Found entity 1: BeMicroMAX10_RodoNios Info (12021): Found 1 design units, including 1 entities, in source file nios_system/synthesis/nios_system.v Info (12023): Found entity 1: nios_system Info (12127): Elaborating entity "BeMicroMAX10_RodoNios" for the top level hierarchy Info (12128): Elaborating entity "nios_system" for hierarchy "nios_system:NiosII" Error (12006): Node instance "leds" instantiates undefined entity "nios_system_LEDs" Error (12006): Node instance "jtag_uart_0" instantiates undefined entity "nios_system_jtag_uart_0" Error (12006): Node instance "nios2_processor" instantiates undefined entity "nios_system_nios2_processor" Error (12006): Node instance "onchip_memory" instantiates undefined entity "nios_system_onchip_memory" Error (12006): Node instance "switches" instantiates undefined entity "nios_system_switches" Error (12006): Node instance "mm_interconnect_0" instantiates undefined entity "nios_system_mm_interconnect_0" Error (12006): Node instance "irq_mapper" instantiates undefined entity "nios_system_irq_mapper" Error (12006): Node instance "rst_controller" instantiates undefined entity "altera_reset_controller" Error (12006): Node instance "rst_controller_001" instantiates undefined entity "altera_reset_controller" Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 9 errors, 0 warnings Error: Peak virtual memory: 630 megabytes Error: Processing ended: Fri Aug 14 18:03:57 2015 Error: Elapsed time: 00:00:09 Error: Total CPU time (on all processors): 00:00:23 Error (293001): Quartus II Full Compilation was unsuccessful. 11 errors, 0 warnings1 Reply
Hello Rodo
I've got a similar error on the same tutorial but using Quartus 13.1. Its is seems that compilation fails due to Error (12006). I've followed this https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03142013_949.html That solved my problem. You just need to add all files from the assignments --> settings --> files menu after putting the nios_system.qip in you project folder. Then compile the project.
