11 years agoCan't compile tutorial: Introduction to the Altera Qsys System Integration Tool?
Hi all, I'm using Quartus 15.0.2 and I'm trying to learn about Nios using this tutorial: ftp://ftp.altera.com/up/pub/altera_material/15.0/tutorials/introduction_to_the_altera_qsys_tool.pdf...
11 years agoHello Rodo
I've got a similar error on the same tutorial but using Quartus 13.1. Its is seems that compilation fails due to Error (12006). I've followed this https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03142013_949.html That solved my problem. You just need to add all files from the assignments --> settings --> files menu after putting the nios_system.qip in you project folder. Then compile the project.
