16 years agoCan't build project in the NIOS II IDE
i have a DE1 board with Cyclone II EP2C20.. device. I designed my hardware and add all the required components in the SOPC Builder. I use now On-Chip-Memory (later i will use flash for programming). I created new software project in the NIOS II IDE and so on, but i got following error message when i try to build the project in the NIOS II IDE. "ld: region onchip_memory2_0 is full (Loto_Generator.elf section .text). Region needs to be 35120 bytes larger. Loto_Generator line 0 1259878959171 305 ld: section .bss [00006004 -> 00006223] overlaps section .text [000041c8 -> 0000f9cb] Loto_Generator line 0 1259881350484 337 ld: section .rodata [00004020 -> 000045c7] overlaps section .exceptions [00004020 -> 000041c7] Loto_Generator line 0 1259881350484 335 ld: section .rwdata [000045c8 -> 00006003] overlaps section .text [000041c8 -> 0000f9cb] Loto_Generator line 0 1259881350484 336" The problem is that i can't use to much size of On-Chip-Memory because my design uses then to much M4K blocks and it doesn't pass the compilation process in the Fitter. Can anyone please help me? I know i could use SRAM memory instead On-Chip, but is there another option? Thanks in advance!2 Replies
I replied to your PM. Your code is too big for your onchip memory and your chip is apparently not large enough to avail you much more onchip memory. I would use the SRAM.
Jake - Altera_Forum
Thanks Jake. You're replies are useful! I will now try with the SRAM.
