16 years agoCan't build project in the NIOS II IDE
Hi, i have a DE1 board with Cyclone II EP2C20.. device. I designed my hardware and add all the required components in the SOPC Builder. I use now On-Chip-Memory (later i will use flash for prog...
16 years agoI replied to your PM. Your code is too big for your onchip memory and your chip is apparently not large enough to avail you much more onchip memory. I would use the SRAM.
Jake
