13 years ago
Can I upload Nios2 SMP system?
Hi, guys & Altera corp.
I'm now making a Nios2 SMP system for my research purpose. It's still a little bit buggy and slow, but I succeeded to boot Linux kernel and execute bash.
Linux version 2.6.30 (hamada@Messiah2) (gcc version 4.1.2 (Wind River Linux Sour
cery G++ 4.1-176))# 1915 SMP Tue Sep 4 18:16:32 JST 2012
console  enabled
Early printk initialized
Linux/Nios II-MMU
Altera Nios II-MMU support (C) 2004 Wind River Systems.
init_bootmem_node(?,0x3d0, 0x0, 0x8000)
free_bootmem(0x3d0000, 0x7c30000)
reserve_bootmem(0x3d0000, 0x1000)
Detected 1 available secondary CPU(s)
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
Kernel command line: kgdboc=ttyS0, 115200 kgdbwait
NR_IRQS:32
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
We have 32768 pages of RAM
Memory available: 125824k/3902k RAM, 0k/0k ROM (1457k kernel code, 2445k data)
Calibrating delay loop... 19.55 BogoMIPS (lpj=97792)
Mount-cache hash table entries: 512
CPU1: Booted secondary processor
Calibrating delay loop... 19.96 BogoMIPS (lpj=99840)
Brought up 2 CPUs
SMP: Total of 2 processors activated (39.52 BogoMIPS).
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
msgmni has been set to 246
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
ttyJ0 at MMIO 0xa60a440 (irq = 2) is a Altera JTAG UART
console handover: boot  -> real
ttyS0 at MMIO 0x8000060 (irq = 3) is a Altera UART
ifconfig: socket: Function not implemented
Welcome to
          ____ _  _
         /  __| ||_|
    _   _| |  | | _ ____  _   _  _  _
   | | | | |  | || |  _ \| | | |\ \/ /
   | |_| | |__| || | | | | |_| |/    \
   |  ___\____|_||_|_| |_|\____|\_/\_/
   |_|
For further information check:
http://www.uclinux.org/
Why came here? CPU0, task inetd pte c71f4c40, entry 07a0704b, address 2ab10000
BusyBox v1.14.2 (2012-06-26 16:39:29 JST) hush - the humble shell
Enter 'help' for a list of built-in commands.
/#  ls
bin   etc   init  mnt   root  sys   usr
dev   home  lib   proc  sbin  tmp   var
/#  bash #  ls -lp
drwxr-xr-x    2 root     root            0 Sep  4  2012 bin/
drwxr-xr-x    6 root     root            0 Sep  4  2012 dev/
drwxr-xr-x    5 root     root            0 Sep  4  2012 etc/
drwxr-xr-x    3 root     root            0 Sep  4  2012 home/
lrwxrwxrwx    1 root     root           10 Sep  4  2012 init -> /sbin/init
drwxr-xr-x    3 root     root            0 Sep  4  2012 lib/
drwxr-xr-x    2 root     root            0 Sep  4  2012 mnt/
dr-xr-xr-x   34 root     root            0 Nov 30 00:00 proc/
drwxr-xr-x    2 root     root            0 Sep  4  2012 root/
lrwxrwxrwx    1 root     root            3 Sep  4  2012 sbin -> bin/
drwxr-xr-x   11 root     root            0 Nov 30 00:00 sys/
drwxr-xr-x    2 root     root            0 Nov 30 00:01 tmp/
drwxr-xr-x    5 root     root            0 Sep  4  2012 usr/
drwxr-xr-x    7 root     root            0 Nov 30 00:01 var/ #  cat /proc/cpuinfo
CPU:         NIOS2 MultiCore
MMU:            ways:16 entries:512
FPU:            none
Clocking:       <not supported>
BogoMips:       19.96
Calibration:    9984000 loops
FPU:            none
BogoMips:       19.96
Calibration:    9984000 loops #  cat /proc/interrupts
           CPU0
  0:      13931     NIOS2-INTC  timer
  2:        133     NIOS2-INTC  JTAGUART
  3:          0     NIOS2-INTC  UART
 30:       4875     NIOS2-INTC  IPI 0
 31:      17375     NIOS2-INTC  IPI 1 #  cat /proc/stat
cpu  124 0 27259 1939 0 0 2 0 0
cpu0 54 0 13448 1183 0 0 2 0 0
cpu1 70 0 13811 756 0 0 0 0 0
intr 38284 14687 0 163 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 515
9 18275
ctxt 33554
btime 943920000
processes 674
procs_running 2
procs_blocked 0 #
The cpu core is a clone of the genuine Nios2/f core and almost all features are implemented except the details of 1st data cache.
If anyone has interest, I want to upload these to 'Altera Wiki', but it's a problem because the 'cpu' is a clone and Altera corp. has their copyright for Nios2's instruction set and its architecture. If Altera corp. kindly permit me to upload all including hardware's source codes, this is the best way. But if not so, how can we share these result?
Kazu
    --- Quote Start ---
    I succeeded to make a Nios2 SMP system by using normal Nios2/f cores.
    --- Quote End ---
    Sounds great.
    But how did you handle cache synchronization and the inter-CPU atomic operations that are necessary to do the Mutex API and the multiple Kernel-internal synchronization issues ?
    (I understand that this is close to impossible without modifying the CPU design.)
    -Michael
    --- Quote Start ---
    --- Quote End ---
    At first, I removed the normal data cache from the Nios2/f core (select the data cache <none> option in the SOPC builder) and added my original 1st (write-through) data cache. The cache synchronization method is the same one that is used in the clone's case. For atomic memory operations, I implemented the 'swap' that is controlled as a custom instruction. Unfortunately, we can't use cache non-cache information outside of Nios2 core, so I changed the kernel memory mapping like
    0xc0000000-0xcfffffff  : cacheable
    0xd0000000-0xdfffffff  : non-cacheable
    0xe0000000-0xefffffff  : cacheable
    0xf0000000-0xffffffff  : non-cacheable
    Kazu
    --- Quote Start ---
    --- Quote End ---
    AFAIK, that would include doing an additional memory interface for this instruction, as the infrastructure of the NIOS design does not allow using the processor's memory interface in a custom instruction. This of course prevents allowing for a cache within the processor. I suppose doing an external cache (aka 2nd level cache) instead of using the 1st leve cache provided by Altera will slow down the CPU a lot.
    --- Quote Start ---
    --- Quote End ---
    Maybe you could use the old A31-trick (A31=1 -> cache bypassed). With that you could define non-cacheable regions using the MMU target address.
    But I don't think the problem with inter-CPU atomic instructions is solvable :(.
    -Michael
    --- Quote Start ---
    --- Quote End ---
    To make a SMP system with normal Nios2, we must achieve next 2 points.
    1) Atomic read-write memory instruction.
    2) Coherency of 1st data caches
    For atomic memory instructions, it is a kind of the game 'Beach Flags' (in this case the amount of flags is only one and this corresponds to a locking variable). So the flag must be set in the 2nd cache or main memory, not in the 1st caches. This means that the bus lock for atomic instructions is required between 1st cache and 2nd cache, not between cpu and 1st cache, So we can achieve 1) without tampering the Altera's data cache. But for 2), there is no method to flush the aimed line by external hardware, so it's impossible to achieve it except removing the normal data cache.
    Of course, we must accept the disadvantage to add an external 1st data cache. It makes the cpu slow, but not a lot. Now to read and write between the cpu and external 1st cache, it takes 3 clocks in the case of cache-hit. But the codes are not fully occupied by 'load ' and 'store' instructions, so the bad influences are limited. (Less memory access is the major premise for RISC processors, though it is sometimes broken:D.)
    And there are some advantages to adopt the external 1st cache. We can make the caches all physically-indexed and physically-tagged type, so the 1st data cache size can be enlarged beyond 4Kbytes without synonym problems. Moreover the bus between the 1st and 2nd cache can be made original, e.g. wider bus width or simultaneously readable & writeable. I adopt 128bits bus size and the peak data rates reaches 1.6GBytes/sec(@100MHz).
    --- Quote Start ---
    --- Quote End ---
    Yes, I used A28-trick.
    --- Quote Start ---
    --- Quote End ---
    If it is unsolvable, the Linux never boot;).
    Kazu
