14 years agoCan I upload Nios2 SMP system?
Hi, guys & Altera corp. I'm now making a Nios2 SMP system for my research purpose. It's still a little bit buggy and slow, but I succeeded to boot Linux kernel and execute bash.
Linux ...
13 years ago --- Quote Start --- I implemented the 'swap' that is controlled as a custom instruction. --- Quote End --- AFAIK, that would include doing an additional memory interface for this instruction, as the infrastructure of the NIOS design does not allow using the processor's memory interface in a custom instruction. This of course prevents allowing for a cache within the processor. I suppose doing an external cache (aka 2nd level cache) instead of using the 1st leve cache provided by Altera will slow down the CPU a lot. --- Quote Start --- Unfortunately, we can't use cache non-cache information outside of Nios2 core, so I changed the kernel memory mapping --- Quote End --- Maybe you could use the old A31-trick (A31=1 -> cache bypassed). With that you could define non-cacheable regions using the MMU target address. But I don't think the problem with inter-CPU atomic instructions is solvable :(. -Michael
