13 years agoCan I upload Nios2 SMP system?
Hi, guys & Altera corp.
I'm now making a Nios2 SMP system for my research purpose. It's still a little bit buggy and slow, but I succeeded to boot Linux kernel and execute bash.
Linux version 2.6.30 (hamada@Messiah2) (gcc version 4.1.2 (Wind River Linux Sour
cery G++ 4.1-176))# 1915 SMP Tue Sep 4 18:16:32 JST 2012
console enabled
Early printk initialized
Linux/Nios II-MMU
Altera Nios II-MMU support (C) 2004 Wind River Systems.
init_bootmem_node(?,0x3d0, 0x0, 0x8000)
free_bootmem(0x3d0000, 0x7c30000)
reserve_bootmem(0x3d0000, 0x1000)
Detected 1 available secondary CPU(s)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: kgdboc=ttyS0, 115200 kgdbwait
NR_IRQS:32
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
We have 32768 pages of RAM
Memory available: 125824k/3902k RAM, 0k/0k ROM (1457k kernel code, 2445k data)
Calibrating delay loop... 19.55 BogoMIPS (lpj=97792)
Mount-cache hash table entries: 512
CPU1: Booted secondary processor
Calibrating delay loop... 19.96 BogoMIPS (lpj=99840)
Brought up 2 CPUs
SMP: Total of 2 processors activated (39.52 BogoMIPS).
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
msgmni has been set to 246
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
ttyJ0 at MMIO 0xa60a440 (irq = 2) is a Altera JTAG UART
console handover: boot -> real
ttyS0 at MMIO 0x8000060 (irq = 3) is a Altera UART
ifconfig: socket: Function not implemented
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Why came here? CPU0, task inetd pte c71f4c40, entry 07a0704b, address 2ab10000
BusyBox v1.14.2 (2012-06-26 16:39:29 JST) hush - the humble shell
Enter 'help' for a list of built-in commands.
/# ls
bin etc init mnt root sys usr
dev home lib proc sbin tmp var
/# bash # ls -lp
drwxr-xr-x 2 root root 0 Sep 4 2012 bin/
drwxr-xr-x 6 root root 0 Sep 4 2012 dev/
drwxr-xr-x 5 root root 0 Sep 4 2012 etc/
drwxr-xr-x 3 root root 0 Sep 4 2012 home/
lrwxrwxrwx 1 root root 10 Sep 4 2012 init -> /sbin/init
drwxr-xr-x 3 root root 0 Sep 4 2012 lib/
drwxr-xr-x 2 root root 0 Sep 4 2012 mnt/
dr-xr-xr-x 34 root root 0 Nov 30 00:00 proc/
drwxr-xr-x 2 root root 0 Sep 4 2012 root/
lrwxrwxrwx 1 root root 3 Sep 4 2012 sbin -> bin/
drwxr-xr-x 11 root root 0 Nov 30 00:00 sys/
drwxr-xr-x 2 root root 0 Nov 30 00:01 tmp/
drwxr-xr-x 5 root root 0 Sep 4 2012 usr/
drwxr-xr-x 7 root root 0 Nov 30 00:01 var/ # cat /proc/cpuinfo
CPU: NIOS2 MultiCore
MMU: ways:16 entries:512
FPU: none
Clocking: <not supported>
BogoMips: 19.96
Calibration: 9984000 loops
FPU: none
BogoMips: 19.96
Calibration: 9984000 loops # cat /proc/interrupts
CPU0
0: 13931 NIOS2-INTC timer
2: 133 NIOS2-INTC JTAGUART
3: 0 NIOS2-INTC UART
30: 4875 NIOS2-INTC IPI 0
31: 17375 NIOS2-INTC IPI 1 # cat /proc/stat
cpu 124 0 27259 1939 0 0 2 0 0
cpu0 54 0 13448 1183 0 0 2 0 0
cpu1 70 0 13811 756 0 0 0 0 0
intr 38284 14687 0 163 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 515
9 18275
ctxt 33554
btime 943920000
processes 674
procs_running 2
procs_blocked 0 #
The cpu core is a clone of the genuine Nios2/f core and almost all features are implemented except the details of 1st data cache. If anyone has interest, I want to upload these to 'Altera Wiki', but it's a problem because the 'cpu' is a clone and Altera corp. has their copyright for Nios2's instruction set and its architecture. If Altera corp. kindly permit me to upload all including hardware's source codes, this is the best way. But if not so, how can we share these result? Kazu15 Replies
--- Quote Start --- I succeeded to make a Nios2 SMP system by using normal Nios2/f cores. --- Quote End --- Sounds great. But how did you handle cache synchronization and the inter-CPU atomic operations that are necessary to do the Mutex API and the multiple Kernel-internal synchronization issues ? (I understand that this is close to impossible without modifying the CPU design.) -Michael - Altera_Forum
--- Quote Start --- But how did you handle cache synchronization and the inter-CPU atomic operations that are necessary to do the Mutex API and the multiple Kernel-internal synchronization issues ? (I understand that this is close to impossible without modifying the CPU design.) --- Quote End --- At first, I removed the normal data cache from the Nios2/f core (select the data cache <none> option in the SOPC builder) and added my original 1st (write-through) data cache. The cache synchronization method is the same one that is used in the clone's case. For atomic memory operations, I implemented the 'swap' that is controlled as a custom instruction. Unfortunately, we can't use cache non-cache information outside of Nios2 core, so I changed the kernel memory mapping like
. Kazu0xc0000000-0xcfffffff : cacheable 0xd0000000-0xdfffffff : non-cacheable 0xe0000000-0xefffffff : cacheable 0xf0000000-0xffffffff : non-cacheable - Altera_Forum
--- Quote Start --- I implemented the 'swap' that is controlled as a custom instruction. --- Quote End --- AFAIK, that would include doing an additional memory interface for this instruction, as the infrastructure of the NIOS design does not allow using the processor's memory interface in a custom instruction. This of course prevents allowing for a cache within the processor. I suppose doing an external cache (aka 2nd level cache) instead of using the 1st leve cache provided by Altera will slow down the CPU a lot. --- Quote Start --- Unfortunately, we can't use cache non-cache information outside of Nios2 core, so I changed the kernel memory mapping --- Quote End --- Maybe you could use the old A31-trick (A31=1 -> cache bypassed). With that you could define non-cacheable regions using the MMU target address. But I don't think the problem with inter-CPU atomic instructions is solvable :(. -Michael - Altera_Forum
--- Quote Start --- AFAIK, that would include doing an additional memory interface for this instruction, as the infrastructure of the NIOS design does not allow using the processor's memory interface in a custom instruction. This of course prevents allowing for a cache within the processor. I suppose doing an external cache (aka 2nd level cache) instead of using the 1st leve cache provided by Altera will slow down the CPU a lot. --- Quote End --- To make a SMP system with normal Nios2, we must achieve next 2 points. 1) Atomic read-write memory instruction. 2) Coherency of 1st data caches For atomic memory instructions, it is a kind of the game 'Beach Flags' (in this case the amount of flags is only one and this corresponds to a locking variable). So the flag must be set in the 2nd cache or main memory, not in the 1st caches. This means that the bus lock for atomic instructions is required between 1st cache and 2nd cache, not between cpu and 1st cache, So we can achieve 1) without tampering the Altera's data cache. But for 2), there is no method to flush the aimed line by external hardware, so it's impossible to achieve it except removing the normal data cache. Of course, we must accept the disadvantage to add an external 1st data cache. It makes the cpu slow, but not a lot. Now to read and write between the cpu and external 1st cache, it takes 3 clocks in the case of cache-hit. But the codes are not fully occupied by 'load ' and 'store' instructions, so the bad influences are limited. (Less memory access is the major premise for RISC processors, though it is sometimes broken:D.) And there are some advantages to adopt the external 1st cache. We can make the caches all physically-indexed and physically-tagged type, so the 1st data cache size can be enlarged beyond 4Kbytes without synonym problems. Moreover the bus between the 1st and 2nd cache can be made original, e.g. wider bus width or simultaneously readable & writeable. I adopt 128bits bus size and the peak data rates reaches 1.6GBytes/sec(@100MHz). --- Quote Start --- Maybe you could use the old A31-trick (A31=1 -> cache bypassed). With that you could define non-cacheable regions using the MMU target address. --- Quote End --- Yes, I used A28-trick. --- Quote Start --- But I don't think the problem with inter-CPU atomic instructions is solvable :(. --- Quote End --- If it is unsolvable, the Linux never boot;). Kazu - Altera_Forum
I uploaded the example files on 'Altera Wiki'. Please see http://www.alterawiki.com/wiki/nios2_smp_system. Later I will upload sources and explanations. Merry X'mas (and this new editor is stupid too.) Kazu
