20 years ago
Can I update and save file when n2linux running?
hi all:
I want to update some files( for example: rework the prime IP setting in
`etc/inittab) when the nios2 uclinux is running. Then reset the DVB, the uclinux
will confing the system bases the updated inittab file.
I think to I can use these function :file_open, file_read, file_write to rework the
file of I want to rework. But the nios2 uclinux is ramfs,so the file just a allude file.
The fact file is stored in flash. Can I rework the fact file ? If can, how can I do?
Who can give me some advice? Thanks a lot.
    good.
    the mtd block is working.
    now you can try erase again and mount jffs2 on it.
    --- Quote Start ---
    originally posted by hippo@Jul 31 2006, 09:00 AM
    good.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17286)
    --- quote end ---
    --- Quote End ---
    I use "# mount -t jffs2 /dev/mtdblock0 /mnt"
    but the erro information is:
    +++++++++++++++++++++++++++++++++++++++++++++++++++++# mount -t jffs2 /dev/mtdblock0 /mnt
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x6548 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x6a6f in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x3273 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x7473 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x6c69 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x3a0a in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x6e69 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0a68 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x6d65 in
    stead
    jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x783a in
    stead
    Further such events for this erase block will not be printed
    Eep. No valid nodes for ino# 1#
    why?
