20 years agoCan I update and save file when n2linux running?
hi all: I want to update some files( for example: rework the prime IP setting in `etc/inittab) when the nios2 uclinux is running. Then reset the DVB, the uclinux will confing the sy...
20 years ago --- Quote Start --- originally posted by hippo@Jul 31 2006, 09:00 AM good.
the mtd block is working.
now you can try erase again and mount jffs2 on it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17286)
--- quote end ---
--- Quote End --- I use "# mount -t jffs2 /dev/mtdblock0 /mnt" but the erro information is: +++++++++++++++++++++++++++++++++++++++++++++++++++++# mount -t jffs2 /dev/mtdblock0 /mnt jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x6548 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x6a6f in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x3273 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x7473 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x6c69 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x3a0a in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x6e69 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0a68 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x6d65 in stead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x783a in stead Further such events for this erase block will not be printed Eep. No valid nodes for ino# 1# +++++++++++++++++++++++++++++++++++++++++++++++++++++ why?
