19 years agoC2H questions, need help
Hi!
i've tried to implement an example to evaluate C2H. i've accelerated a function named testalg. c2h compiles it, in the sopc builder everything is fine, the quartus flow doesn't report any errors, nor the C2H Register build log at Nios II IDE says anything. it looks everything fine, but the result is always -1 here's the whole code # include <stdio.h> int testalg(int a, int b ) { return a*a + b*b; } int main() { int sum = 0; printf("sum before = %d\n",sum); sum = testalg(5,5); printf("sum after = %d\n",sum); printf("should be 50\n"); return 0; } P.S. can i avoid the c2h compiler to restart the whole quartus flow, when i just change something in the software project, and not in the acceleration function? Thanks 4 reading and it would be good, if someone can help me out greetz Andreas1 Reply
hi!
i've solved the problem. just in case someone else has the same problem in the future. the problem was, that i was not sure if the c2h compiler, which starts the flow, also downloads the sof file. and i also didn't recognise that i have to download the time limited sof file and not the standard sof file (i just have an evaluation license at the moment) so far merry xmas Andreas
