19 years agoC2H questions, need help
Hi! i've tried to implement an example to evaluate C2H. i've accelerated a function named testalg. c2h compiles it, in the sopc builder everything is fine, the quartus flow doesn'...
19 years agohi!
i've solved the problem. just in case someone else has the same problem in the future. the problem was, that i was not sure if the c2h compiler, which starts the flow, also downloads the sof file. and i also didn't recognise that i have to download the time limited sof file and not the standard sof file (i just have an evaluation license at the moment) so far merry xmas Andreas
