20 years agoC++ classes...
Hey Guys,
is it possible to do object oriented programming in NIOSII? when I define a simple class in a .h or .hpp file, I get syntax errors all over the place.... I even get errors for using the word "class"... can someone please provide some insight into whether it is even possible to program C++ in NIOSII? thanks, Aydin.4 Replies
I have not had any problems. I just rename the file created by the new application wizard from a .c to a .cpp file (hello_world.c or whatever) and it works fine.
That is not the problem... I am having trouble declaring my own classes... I want to be able to declare a really simple class... however, in order to declare a class, I need to include iostream and this I cannot do properly.... if there is anyone out there that has been able to run a very simple c++ program, please please explain how you can include iostream...# include <iostream> does not work... thanks, [email protected] - Altera_Forum
--- Quote Start --- originally posted by aym35@Nov 15 2005, 04:36 PM hey guys,is it possible to do object oriented programming in niosii?
when i define a simple class in a .h or .hpp file, i get syntax
i even get errors for using the word "class"...
even possible to program c++ in niosii?
thanks,
aydin.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11002)
--- quote end ---
--- Quote End --- I noticed the compiler behaves different if the file extention is ".c" instead of ".cpp". I had trouble wheni included a header containing cpp in a normal c file. Otherwise cpp works fine. Karsten
Similarly, the compiler will treat ".c" and ".C" differently.
-Joel- I noticed the compiler behaves different if the file extention is ".c" instead of ".cpp". I had trouble wheni included a header containing cpp in a normal c file. Otherwise cpp works fine. Karsten
