20 years agoC++ classes...
Hey Guys, is it possible to do object oriented programming in NIOSII? when I define a simple class in a .h or .hpp file, I get syntax errors all over the place.... I even get errors...
20 years agoSimilarly, the compiler will treat ".c" and ".C" differently.
-Joel- I noticed the compiler behaves different if the file extention is ".c" instead of ".cpp". I had trouble wheni included a header containing cpp in a normal c file. Otherwise cpp works fine. Karsten
