12 years agoC and Assembly language inside the eclipse for NIOS II
Is this possible to have combination of C and Assembly language inside the eclipse for NIOS II? In Visual studio you can write your C code and add some assembly code using __asm key, is there any similar command in the eclipse for NIOS II? I have some multiplication and division which I would like to modify its algorithm to increase the calculation speed. Please give me some suggestion.1 Reply
Eclipse uses GCC compiler ported for Nios II processor, so what you look for is asm() function.
http://www.ibiblio.org/gferg/ldp/gcc-inline-assembly-howto.html
