12 years agoC and Assembly language inside the eclipse for NIOS II
Hi, Is this possible to have combination of C and Assembly language inside the eclipse for NIOS II? In Visual studio you can write your C code and add some assembly code using __asm key, is ther...
12 years agoEclipse uses GCC compiler ported for Nios II processor, so what you look for is asm() function.
http://www.ibiblio.org/gferg/ldp/gcc-inline-assembly-howto.html
