left's avatar
left
3 years ago
byte alignment
Does the Nios V allow un-aligned 32-bit access to memory? I know nios ii doesn't. If it doesn't I wish it did.
  • KellyJialin_Goh's avatar
    KellyJialin_Goh
    Greetings and welcome to Intel's forum.
    Unfortunately, Platform Designer does not attempt to align separate memory components in a contiguous memory range. For example, if you want multiple On-Chip Memory components addressable as one contiguous memory range, you must explicitly assign base addresses.
    Also, may I know the reason you would like to have un-aligned 32-bit access to memory?
    Here is the information on NIOS V handbook section 2.1.3. Specifying Base Addresses and Interrupt Request Priorities: https://www.intel.com/programmable/technical-pdfs/726952.pdf
    Thank you.
    Kelly Jialin, GOH
    KellyJialin_Goh
    Any updates from your end? Is there any further help needed to clear your doubts?
    Thank you.
    Kelly
    KellyJialin_Goh
    Hope to hear on your feedback.
    Thank you.
    Kelly
    KellyJialin_Goh
    Thank you.
    Kelly Jialin, GOH
