20 years agoBuildroot - Add user apps Problem
I try to run Hippos - Buildroot topic 3174 step 11. Add user apps proted to uClinux ... but aftercd ~/uClinux-dist-test
make menuconfig I get this Saving your kernel configuration... *** End of Linux kernel configuration. *** Check the top-level Makefile for additional cofiguration. *** Next, you must run 'make dep' ************************ NOTICE ********************** There is no preset config for linux-2.6.x on Platform SnapGear/LITE300. If you choose to continue you will have to setup a linux config from scratch which is a very complex task. You will find it easier if you can copy a conig.linux-2.6.x from another platform that is similar. If you know what you are doing press <ENTER> otherwise Type^C to abort. make: *** [menuconfig] Interrupt Every example up to here runs fine (thanx to Hippo) with my Altera Cyclon Devboard. I'm using SUSE (Novel) 9.3 and I'm a absolut beginner with Linux .... From / To where I have to copy a "preset config", as I look in the description it has to run without any interaction. Of course I do not like to setup from scratch ... Thank you all in advance for your response. Nep2 Replies
Hi Nepomuk,
Welcome. It looks like the patches and config are wrong. Please make sure you have the uClinux-dist.diff unzipped from build.zip in ~/download dir. Then build uClinux-dist-test again with,
In main menu, check Vendor/Product Selection ---> should be (altera), (nios2nommu) Kernel/Library/Defaults Selection ---> select only Customize Vendor/User Settings (NEW) <exit><exit> Do you wish to save your new kernel configuration?<yes> Next it will show Core Applications .... etc selections. <exit> Do you wish to save your new kernel configuration?<yes> Thencd ~ rm -rf ~/uClinux-dist-test tar jxf ~/download/uClinux-dist-test-20051209.tar.bz2 cd ~/uClinux-dist-test patch -p0 <~/download/uClinux-dist.diff touch ~/uClinux-dist-test/vendors/Altera/nios2nommu/inittab make menuconfigmake subdirs make romfs - Altera_Forum
Hi Hippo,
you were right - the "uClinux-dist-test" was not patched !! Thanks a lot for your help ! Nep
