20 years agoBuildroot - Add user apps Problem
Hi, I try to run Hippos - Buildroot topic 3174 step 11. Add user apps proted to uClinux ... but after cd ~/uClinux-dist-test
make menuconfig I get this Saving your kernel con...
20 years agoHi Nepomuk,
Welcome. It looks like the patches and config are wrong. Please make sure you have the uClinux-dist.diff unzipped from build.zip in ~/download dir. Then build uClinux-dist-test again with,cd ~
rm -rf ~/uClinux-dist-test
tar jxf ~/download/uClinux-dist-test-20051209.tar.bz2
patch -p0 <~/download/uClinux-dist.diff
touch ~/uClinux-dist-test/vendors/Altera/nios2nommu/inittab
make menuconfig In main menu, check Vendor/Product Selection ---> should be (altera), (nios2nommu) Kernel/Library/Defaults Selection ---> select only Customize Vendor/User Settings (NEW) <exit><exit> Do you wish to save your new kernel configuration?<yes> Next it will show Core Applications .... etc selections. <exit> Do you wish to save your new kernel configuration?<yes> Then make subdirs
make romfs
