21 years agobuilding project problem
Hi:
I followed the steps of the document "ecos of niosII" from step 6.1 to 6.3 ,and they are right. when I went to step 7: using IDE , I did according the document and set the "make INSTALL_DIR=/cygdrive/f/etest/test_install" ( f/etest/test_install is the directoy of the ecos project), when I choose the command "build project", the process is stopped because of the belown errors: make INSTALL_DIR=/cygdrive/f/etest/test_install all make: *** No rule to make target `all'. Stop. the tools of me are: QII5.0, nios5.0 b73c, ecos5nios5 os:xp sp2 who can help me? thks4 Replies
It looks like you haven't created the project in the correct directory. The project directory should contain a makefile (like the one provided in the examples directory).
Hi monkey:
I tried it again according to you but the result is same and failure, there was my steps: 1)nios2configtool --ptf=/.././../std_1c20.ptf --cpu=cpu and start the config diag. 2)choose the template "altera niosII board" and set "startup"=>"ROMRAM" ,SAVE the pjoject:" test" in the directory "h:/etest" 3)build->library the building finished and no erro. 4)I copy all the files in the directory " /../../ecos_current/examples " to the " h:/etest" 5)change to the directory :cd h:/etest 6)in the directory , make INSTALL_DIR=/cygdrive/h/etest/test_install ,and the procedure is successful and a serials of *.o files were created. 7) "start=>program=>altera=>niosII IDE" 8)file=>new=>project 9) append "altera niosII " and choose "Advanced c/c++ Project" ,then click next 10)filled the niosII project 's name is: hello_ecos ,and unselect "use the default location" ,settintg it to "h:/etest" , which is the directory of the "ecos build project" 11)click next ,choose "maker builder" ,in the build command set "make INSTALL_DIR=/cygdrive/h/etest/test_install" and others did not change. 12)click "finish" 13)right click the niosii project "hello_ecos" and choose "build project" ,then the result is appear make INSTALL_DIR=/cygdrive/h/etest/test_install all make: *** No rule to make target `all'. Stop. why wrong is it ? I am crazy and the deadline is going. Can you or others help me? - Altera_Forum
I can't see what the problem is here, unless you've accidentally deleted the "all" target from your makefile.
If you have a tight deadline, then you are probably best sticking with the command line build - since that seems to be working for you. - Altera_Forum
Hi:
the following is all context of my make file: # Mostly written by Jonathan Larmour, Red Hat, Inc.# Reference to ecos.mak added by John Dallaway, eCosCentric Limited, 2003-01-20# This file is in the public domain and may be used for any purpose # Usage: make INSTALL_DIR=/path/to/ecos/install INSTALL_DIR=$$(INSTALL_DIR)# override on make command line include $(INSTALL_DIR)/include/pkgconf/ecos.mak XCC = $(ECOS_COMMAND_PREFIX)gcc XCXX = $(XCC) XLD = $(XCC) CFLAGS = -I$(INSTALL_DIR)/include CXXFLAGS = $(CFLAGS) LDFLAGS = -nostartfiles -L$(INSTALL_DIR)/lib -Ttarget.ld # RULES .PHONY: all clean all: hello twothreads simple-alarm serial clean: -rm -f hello hello.o twothreads twothreads.o -rm -f simple-alarm simple-alarm.o serial serial.o -rm -f instrument-test instrument-test.o %.o: %.c $(XCC) -c -o $*.o $(CFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.cxx $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.C $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.cc $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< hello: hello.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] twothreads: twothreads.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] simple-alarm: simple-alarm.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] serial: serial.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] instrument-test: instrument-test.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] meanwhile ,which is copy from the directory /../ecos_current /examples/ ,I think it is not wrong. are you think so? another question:what is the different workbetween the " program_flash" ultity and "using IDE DEbug" , and if I success to program the flash by using "program_flash" ,I needn't use "using IDE DEBUG" the ecos design?
