21 years agobuilding project problem
Hi: I followed the steps of the document "ecos of niosII" from step 6.1 to 6.3 ,and they are right. when I went to step 7: using IDE , I did according the document and set the "make INSTALL...
21 years agoHi:
the following is all context of my make file: # Mostly written by Jonathan Larmour, Red Hat, Inc.# Reference to ecos.mak added by John Dallaway, eCosCentric Limited, 2003-01-20# This file is in the public domain and may be used for any purpose # Usage: make INSTALL_DIR=/path/to/ecos/install INSTALL_DIR=$$(INSTALL_DIR)# override on make command line include $(INSTALL_DIR)/include/pkgconf/ecos.mak XCC = $(ECOS_COMMAND_PREFIX)gcc XCXX = $(XCC) XLD = $(XCC) CFLAGS = -I$(INSTALL_DIR)/include CXXFLAGS = $(CFLAGS) LDFLAGS = -nostartfiles -L$(INSTALL_DIR)/lib -Ttarget.ld # RULES .PHONY: all clean all: hello twothreads simple-alarm serial clean: -rm -f hello hello.o twothreads twothreads.o -rm -f simple-alarm simple-alarm.o serial serial.o -rm -f instrument-test instrument-test.o %.o: %.c $(XCC) -c -o $*.o $(CFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.cxx $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.C $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< %.o: %.cc $(XCXX) -c -o $*.o $(CXXFLAGS) $(ECOS_GLOBAL_CFLAGS) $< hello: hello.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] twothreads: twothreads.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] simple-alarm: simple-alarm.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] serial: serial.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] instrument-test: instrument-test.o $(XLD) $(LDFLAGS) $(ECOS_GLOBAL_LDFLAGS) -o $@ [email protected] meanwhile ,which is copy from the directory /../ecos_current /examples/ ,I think it is not wrong. are you think so? another question:what is the different workbetween the " program_flash" ultity and "using IDE DEbug" , and if I success to program the flash by using "program_flash" ,I needn't use "using IDE DEBUG" the ecos design?
