21 years agobuilding project problem
Hi: I followed the steps of the document "ecos of niosII" from step 6.1 to 6.3 ,and they are right. when I went to step 7: using IDE , I did according the document and set the "make INSTALL...
21 years agoHi monkey:
I tried it again according to you but the result is same and failure, there was my steps: 1)nios2configtool --ptf=/.././../std_1c20.ptf --cpu=cpu and start the config diag. 2)choose the template "altera niosII board" and set "startup"=>"ROMRAM" ,SAVE the pjoject:" test" in the directory "h:/etest" 3)build->library the building finished and no erro. 4)I copy all the files in the directory " /../../ecos_current/examples " to the " h:/etest" 5)change to the directory :cd h:/etest 6)in the directory , make INSTALL_DIR=/cygdrive/h/etest/test_install ,and the procedure is successful and a serials of *.o files were created. 7) "start=>program=>altera=>niosII IDE" 8)file=>new=>project 9) append "altera niosII " and choose "Advanced c/c++ Project" ,then click next 10)filled the niosII project 's name is: hello_ecos ,and unselect "use the default location" ,settintg it to "h:/etest" , which is the directory of the "ecos build project" 11)click next ,choose "maker builder" ,in the build command set "make INSTALL_DIR=/cygdrive/h/etest/test_install" and others did not change. 12)click "finish" 13)right click the niosii project "hello_ecos" and choose "build project" ,then the result is appear make INSTALL_DIR=/cygdrive/h/etest/test_install all make: *** No rule to make target `all'. Stop. why wrong is it ? I am crazy and the deadline is going. Can you or others help me?
