21 years agobuilding project problem
Hi: I followed the steps of the document "ecos of niosII" from step 6.1 to 6.3 ,and they are right. when I went to step 7: using IDE , I did according the document and set the "make INSTALL...
21 years agoI can't see what the problem is here, unless you've accidentally deleted the "all" target from your makefile.
If you have a tight deadline, then you are probably best sticking with the command line build - since that seems to be working for you.
