17 years ago
building problem - toolchain
Your kernel directory 'linux-2.6.x' lacks a vmImage file:
/home/z125188/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/vmImage
This usually means your toolchain lacks u-boot tools. Please check your
toolchain installation. The file is generated when running 'make linux'.
how do i check my toolchain installation? :/
    In normal nios2nommu build, mkimage is not needed. You should use "make" once to build everything.
    Only if you are using "trunk" branch of uClinux-dist, it will need mkimage. mkimage is available from u-boot, you can either install it or build it.
    1. for ubuntu/debian, apt-get install uboot-mkimage
    2. cd nios2-linux/toolchain-build
    make u-boot
    # then move the mkimage to your toolchain binary dir in your PATH.
    - Hippo
    <div class='quotetop'>QUOTE (hippo @ Aug 24 2009, 08:17 PM) <{post_snapback}> (index.php?act=findpost&pid=23567)</div>
    --- Quote Start ---
    make u-boot[/b]
    --- Quote End ---
    Those steps worked fine but i still get the same error.
    I want to try nios2 with MMU
    without it worked fine and i build a lot of zImages but the MMU stuffs not working.
    do i have to move the "mkimage" binary or just add the path to the PATH variable?
    i tried adding it with PATH=$PATH:/home/xyz/nios2-linux/toolchain-build/u-boot/tools
    mfg Sven
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    WARNING: modpost: Found 4 section mismatch(es).
    To see full details build your kernel with:
    &#39;make CONFIG_DEBUG_SECTION_MISMATCH=y&#39;
    GEN .version
    CHK include/linux/compile.h
    UPD include/linux/compile.h
    CC init/version.o
    LD init/built-in.o
    LD .tmp_vmlinux1
    KSYM .tmp_kallsyms1.S
    AS .tmp_kallsyms1.o
    LD .tmp_vmlinux2
    KSYM .tmp_kallsyms2.S
    AS .tmp_kallsyms2.o
    LD vmlinux
    SYSMAP System.map
    SYSMAP .tmp_System.map
    OBJCOPY arch/nios2/boot/vmlinux.bin
    GZIP arch/nios2/boot/vmlinux.gz
    UIMAGE arch/nios2/boot/vmImage
    /usr/bin/mkimage [OPTIONS]
    Options:
    -f <MD5 name> Specify an input MD5 file. MD5s must be in jigdo&#39;s
    pseudo-base64 format
    -j <jigdo name> Specify the input jigdo file
    -t <template name> Specify the input template file
    -m <item=path> Map <item> to <path> to find the files in the mirror
    -M <missing name> Rather than try to build the image, just check that
    all the needed files are available. If any are missing,
    list them in this file.
    -v Make the output logging more verbose
    -l <logfile> Specify a logfile to append to.
    If not specified, will log to stderr
    -o <outfile> Specify a file to write the ISO image to.
    If not specified, will write to stdout
    -q Quick mode. Don&#39;t check MD5sums. Dangerous!
    -s <bytenum> Start byte number; will start at 0 if not specified
    -e <bytenum> End byte number; will end at EOF if not specified
    -z Don&#39;t attempt to rebuild the image; simply print its
    size in bytes
    Kernel: arch/nios2/boot/vmImage is ready
    Building modules, stage 2.
    MODPOST 0 modules
    make[1]: Verlasse Verzeichnis &#39;/home/z125188/nios2-linux/linux-2.6&#39;
    if [ -f linux-2.6.x/vmlinux ]; then
    ln -f linux-2.6.x/vmlinux linux-2.6.x/linux ;
    fi[/b]
    --- Quote End ---
    why is he telling me the vmImage is ready when there is none ? :/
    <div class='quotetop'>QUOTE (SvenHe @ Aug 25 2009, 04:15 PM) <{post_snapback}> (index.php?act=findpost&pid=23585)</div>
    --- Quote Start ---
    I want to try nios2 with MMU[/b]
    --- Quote End ---
    The nios2 linux with MMU is under final testing and will be opened for the public soon. Please wait.
    - Hippo
    I don't want to update this message. But it seems to me that it is related to my issue. After i compiled the kernel, I got this message.
    Image Name: Linux-3.7.0-01377-g1061bd7
    Created: Mon Mar 25 15:41:30 2013
    Image Type: NIOS II Linux Kernel Image (gzip compressed)
    Data Size: 1445018 Bytes = 1411.15 kB = 1.38 MB
    Load Address: c8000000
    Entry Point: c8000000
    Configuring .sof files works smoothly but i could not download vmImage file:
    rootF15: /path/nios2-download vmImage
    nios2-elf-objcopy:./vmImage: File format not recognized
    ./vmImage.srec: Unable to open input file
    rm: cannot remove `./vmImage.srec': No such file or directory
    Have anybody encountered with this problem ? How to obtain zImage ?
