17 years agobuilding problem - toolchain
Your kernel directory 'linux-2.6.x' lacks a vmImage file: /home/z125188/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/vmImage This usually means your toolchain lacks u-boot tools...
17 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- WARNING: modpost: Found 4 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 KSYM .tmp_kallsyms1.S AS .tmp_kallsyms1.o LD .tmp_vmlinux2 KSYM .tmp_kallsyms2.S AS .tmp_kallsyms2.o LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map OBJCOPY arch/nios2/boot/vmlinux.bin GZIP arch/nios2/boot/vmlinux.gz UIMAGE arch/nios2/boot/vmImage /usr/bin/mkimage [OPTIONS] Options: -f <MD5 name> Specify an input MD5 file. MD5s must be in jigdo's pseudo-base64 format -j <jigdo name> Specify the input jigdo file -t <template name> Specify the input template file -m <item=path> Map <item> to <path> to find the files in the mirror -M <missing name> Rather than try to build the image, just check that all the needed files are available. If any are missing, list them in this file. -v Make the output logging more verbose -l <logfile> Specify a logfile to append to. If not specified, will log to stderr -o <outfile> Specify a file to write the ISO image to. If not specified, will write to stdout -q Quick mode. Don't check MD5sums. Dangerous! -s <bytenum> Start byte number; will start at 0 if not specified -e <bytenum> End byte number; will end at EOF if not specified -z Don't attempt to rebuild the image; simply print its size in bytes Kernel: arch/nios2/boot/vmImage is ready Building modules, stage 2. MODPOST 0 modules make[1]: Verlasse Verzeichnis '/home/z125188/nios2-linux/linux-2.6' if [ -f linux-2.6.x/vmlinux ]; then ln -f linux-2.6.x/vmlinux linux-2.6.x/linux ; fi[/b] --- Quote End --- why is he telling me the vmImage is ready when there is none ? :/
