19 years agoBuild uClinux kernel puzzle
Hello everyone:
when I built the uClinux kernel, I was not sure whether it has been built successfully. Because the last information is: " make: Leaving directory `/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' " I remember there should be a "build complete " information if the kernel was built successfully. If it was not, can anyone tell me the reason why it is wrong? My target SOPC project is the example project(cyclone 2c35/standard) of the Nios II kits, And my software edition is Quartus II 6.0, nios II 6.0, Microtronix Nios II Linux Distribution V1.4. I paste the built information below. thanks very much! ------------------------------------------------ ------------------------------------------------ Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' no emulation specific options. Using /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel GEN /cygdrive/d/DengHuanhuan/work/Linux_test/kernel/build/Makefile CHK include/linux/version.h SPLIT include/linux/autoconf.h -> include/config/* CHK include/nios2_system.h HOSTCC scripts/basic/fixdep scripts/basic/.fixdep.d: done. HOSTCC scripts/basic/split-include scripts/basic/.split-include.d: done. HOSTCC scripts/basic/docproc scripts/basic/.docproc.d: done. HOSTCC scripts/mod/mk_elfconfig scripts/mod/.mk_elfconfig.d: done. MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/file2alias.o scripts/mod/.file2alias.o.d: done. HOSTCC scripts/mod/modpost.o scripts/mod/.modpost.o.d: done. HOSTCC scripts/mod/sumversion.o scripts/mod/.sumversion.o.d: done. HOSTLD scripts/mod/modpost HOSTCC scripts/kallsyms scripts/.kallsyms.d: done. make[2]: `arch/nios2nommu/kernel/asm-offsets.s' is up to date. CHK include/asm-nios2nommu/asm-offsets.h CHK include/linux/compile.h HOSTCC usr/gen_init_cpio usr/.gen_init_cpio.d: done. CHK usr/initramfs_list CPIO usr/initramfs_data.cpio GZIP usr/initramfs_data.cpio.gz AS usr/initramfs_data.o usr/.initramfs_data.o.d: done. LD usr/built-in.o LD arch/nios2nommu/kernel/built-in.o CC drivers/mtd/chips/cfi_cmdset_0002.o /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/mtd/chips/cfi_cmdset_0002.c: In function `cfi_amdstd_init': /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/mtd/chips/cfi_cmdset_0002.c:1564: warning: `inter_module_register' is deprecated (declared at /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/include/linux/module.h:573) /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/mtd/chips/cfi_cmdset_0002.c: In function `cfi_amdstd_exit': /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/drivers/mtd/chips/cfi_cmdset_0002.c:1571: warning: `inter_module_unregister' is deprecated (declared at /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/include/linux/module.h:574) drivers/mtd/chips/.cfi_cmdset_0002.o.d: done. LD drivers/mtd/chips/built-in.o CC drivers/mtd/maps/altera.o drivers/mtd/maps/.altera.o.d: done. LD drivers/mtd/maps/built-in.o LD drivers/mtd/built-in.o LD drivers/built-in.o GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o init/.version.o.d: done. LD init/built-in.o LD .tmp_vmlinux1 KSYM .tmp_kallsyms1.S AS .tmp_kallsyms1.o ./..tmp_kallsyms1.o.d: done. LD .tmp_vmlinux2 KSYM .tmp_kallsyms2.S AS .tmp_kallsyms2.o ./..tmp_kallsyms2.o.d: done. LD vmlinux SYSMAP System.map SYSMAP .tmp_System.map Building modules, stage 2. MODPOST make: Leaving directory `/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' --------------------------------------------------------------------9 Replies
--- Quote Start --- originally posted by hippo@Jan 9 2007, 10:14 PM you may follow the wiki,http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20436)
--- quote end ---
--- Quote End --- Thank you hippo, A few days ago I have fellowed a guide and built the kernel successfully, but now the situation is I performed the same steps but the result was not right. The only change to my system is I have updated my quartus II and nios II software to 6.0 edition. So I wonder whether the Microtronix Nios II Linux Distribution V1.4 edition is just fit for the Nios II 5.0? Thank you.
--- Quote Start --- originally posted by 0quanquan0+jan 10 2007, 10:29 am--><div class='quotetop'>quote (0quanquan0 @ jan 10 2007, 10:29 am)</div>--- quote start ---
<!--quotebegin-hippo@Jan 9 2007, 10:14 PM you may follow the wiki,
--- quote end ---
--- Quote End --- Thank you hippo, A few days ago I have fellowed a guide and built the kernel successfully, but now the situation is I performed the same steps but the result was not right. The only change to my system is I have updated my quartus II and nios II software to 6.0 edition. So I wonder whether the Microtronix Nios II Linux Distribution V1.4 edition is just fit for the Nios II 5.0? Thank you. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=20454)</div> [/b] --- Quote End --- Yes, it works with Nios2 5.0 only. So, I would suggest the wiki, which is independent of Nios2 version.
Building a kernel and a filesystem based on the Microtonix distribution works for me with Nios 2 EDS 6.0 and Quartus II 6.0.
<div class='quotetop'>QUOTE </div> --- Quote Start --- I remember there should be a "build complete " information if the kernel was built successfully.[/b] --- Quote End --- i couldn't see this message. check if vmlinux.bin is build. - Altera_Forum
maybe the nios2 is independent with uClinux! before I use Quartus5.0 + Redhat,when I update to Quartus6.0 , only Recomplie my NIOS2 project and use the old uClinux , All is ok!
Thank you all!
Helmchen, it seems that you have the uClinux edition supports Nios II 6.0. Can I download it on the net? and what is the link ? Thanks. - Altera_Forum
--- Quote Start --- Helmchen, it seems that you have the uClinux edition supports Nios II 6.0. Can I download it on the net? and what is the link ? Thanks.[/b] --- Quote End --- you can use the old microtronix distribution. feiwu said <div class='quotetop'>QUOTE </div> --- Quote Start --- maybe the nios2 is independent with uClinux! before I use Quartus5.0 + Redhat,when I update to Quartus6.0 , only Recomplie my NIOS2 project and use the old uClinux , All is ok![/b] --- Quote End --- As i remember there is NO "Build complete" or something similar. So it should work and an vmlinux.bin has been generated. if not, i'm sorry that i cannot give you any hints - Altera_Forum
I unpack and patch the sources as per http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist)
When I come to the vendor hwselect I get a strange error http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif [beham@localhost uClinux-dist]make vendor_hwselect SYSPTF=~/tPadNG/altera_nios_dev_board_cyclone_2c35.ptf make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C vendors vendor_hwselect make[1]: Entering directory `/home/beham/uClinux-dist/vendors' /home/beham/uClinux-dist/config.arch:108: *** commands commence before first target. Stop. make[1]: Leaving directory `/home/beham/uClinux-dist/vendors' make: *** [vendor_hwselect] Error 2 I run FC6 and have installed gcc nios crosscompiler from the wiki page. Anyone got an idea to share on how to sort this one out?? - Altera_Forum
--- Quote Start --- originally posted by hammer459@Jan 15 2007, 07:42 PM i unpack and patch the sources as per http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist)when i come to the vendor hwselect i get a strange error http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/huh.gif
[beham@localhost uclinux-dist]make vendor_hwselect sysptf=~/tpadng/altera_nios_dev_board_cyclone_2c35.ptf
make arch=nios2nommu cross_compile=nios2-linux-uclibc- -c vendors vendor_hwselect
make[1]: entering directory `/home/beham/uclinux-dist/vendors'
/home/beham/uclinux-dist/config.arch:108: *** commands commence before first target. stop.
make[1]: leaving directory `/home/beham/uclinux-dist/vendors'
make: *** [vendor_hwselect] error 2
i run fc6 and have installed gcc nios crosscompiler from the wiki page.
anyone got an idea to share on how to sort this one out??
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20584)
--- quote end ---
--- Quote End --- Sorry, it was a bug in patch ver 29. Please reverse patch ver 29, and use ver 30.
