19 years agoBuild uClinux kernel puzzle
Hello everyone: when I built the uClinux kernel, I was not sure whether it has been built successfully. Because the last information is: " make: Leaving directory `/cygdrive/c/altera/k...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Helmchen, it seems that you have the uClinux edition supports Nios II 6.0. Can I download it on the net? and what is the link ? Thanks.[/b] --- Quote End --- you can use the old microtronix distribution. feiwu said <div class='quotetop'>QUOTE </div> --- Quote Start --- maybe the nios2 is independent with uClinux! before I use Quartus5.0 + Redhat,when I update to Quartus6.0 , only Recomplie my NIOS2 project and use the old uClinux , All is ok![/b] --- Quote End --- As i remember there is NO "Build complete" or something similar. So it should work and an vmlinux.bin has been generated. if not, i'm sorry that i cannot give you any hints
