Bug in "Simple Socket Server" example.
I'm using Quartus 18.0 Std and generated the "Simple Socket Server" with BSP. There is a bug in led.c:
while(1) { /* Wait 50 milliseconds between pattern updates, to make the pattern slow * enough for the human eye, and more impotantly, to give up control so * MicroC/OS-II can schedule other lower priority tasks. */ OSTimeDlyHMSM(0,0,0,1000);
Besides the fact that it says it wants a 50 ms delay and appears to be try and generate a 1000 ms delay, the code for OSTimeDlyHMSM in os_time.c has the following:
if (hours == 0) { if (minutes == 0) { if (seconds == 0) { if (ms == 0) { return (OS_ERR_TIME_ZERO_DLY); } } } } if (minutes > 59) { return (OS_ERR_TIME_INVALID_MINUTES); /* Validate arguments to be within range */ } if (seconds > 59) { return (OS_ERR_TIME_INVALID_SECONDS); } if (ms > 999) { return (OS_ERR_TIME_INVALID_MS); }
So if ms is > 999, as it is here, the function fails.
And I have to wonder why the first part was not written:
if (hours == 0 && minutes == 0 && seconds == 0 && ms == 0) { return (OS_ERR_TIME_ZERO_DLY); }
- BoonBengT_Altera
Moderator
Hi @corestar,
Thank you for posting in Intel community forum and hope this message find you well.
And appreciate that you have pointed out on the gaps notice for the simple socket server design example.
Quick clarification is we may, what are the targeted device mention? And is this the example you referring to?Warm regards.
BB- BoonBengT_Altera
Moderator
Hi @corestar,
Hope this message find you well, by any chances did you managed to look into the clarification mention above?
Warm Regards
BB- corestar
Contributor
I was using the NIOS-II tools for the Arria 10 SoC devel kit. It's been a while and we've abandoned the Arria 10 SoC, but I believe I generated the example design within the NIOS-II tools using the generated example design + BSP option.
