BSP fails to build for FreeRTOS on a Nios V with UART
I have a Nios V on a Max 10 with a UART (RS-232 Serial Port) Intel FPGA IP (and also JTAG UART). When I opened up the BSP editor, I selected FreeRTOS and went with all the defaults and made a BSP. However, when I try building a bare bones hello world C program, the BSP fails to build. It says that the BSP source file altera_avalon_uart_init.c has OS_FLAG_SET as undeclared, and similarly, it says the BSP file altera_avalon_uart_read.c has OS_FLAG_WAIT_SET_ANY undeclared. Also, altera_avalon_uart_write.c has OS_FLAG_CONSUME undeclared. How do I get the BSP to build?
I can use UART with HAL rather than FreeRTOS, and it works fine for the Nios V.
(I am using Quartus 23.1 STD.)
In the "freertos/drivers/src/":
- intel_lw_uart_init.c
- line 228~:
if (sp->tx_start == ((sp->tx_end + 1) & ALT_AVALON_UART_BUF_MSK))
ALT_FLAG_POST (sp->events,
ALT_UART_WRITE_RDY,
ALT_FLAG_SET);
- intel_lw_uart_read.c
- line 205~:
ALT_FLAG_PEND (sp->events,
ALT_UART_READ_RDY,
ALT_FLAG_WAIT_SET_ANY_WITH_CONSUME,
ALT_FLAG_WAIT_MAX_TIMEOUT);
- intel_lw_uart_write.c
- line 192~:
ALT_UART_WRITE_RDY,
- EBERLAZARE_I_Intel
Let me try to reattach:
Again, for MAX 10, making this changes will increase the size of the .elf, and it would not fit the maximum size for MAX 10's OCRAM due to its size. You may continue to use Altera HAL or in the future consider a bigger FPGA.
- line 228~:
ALT_UART_WRITE_RDY,
ALT_FLAG_SET);
- line 205~:
ALT_UART_READ_RDY,
- line 192~:
ALT_UART_WRITE_RDY,
Hi Andrew,
We apologize for any inconvenience. Given this, is it okay to proceed with the Altera HAL with your design? Or do you have other FPGA?
- Andrew099
We're using external flash to do execute in place, and so it doesn't matter to us that the .elf file won't fit on the Max 10 itself. We're still planning on using the Max 10, and given our current design, we have to use FreeRTOS. We think we know what we need to do going forward. Thank you for your help.
