16 years agoBootloader for uClinux-MMU with EPCS
I'd like to load uClinux-MMU from the EPCS. The physical address for instruction memory is 0x02000000, so the only way to access it is through the TLB. The default boot copier supplied for the EPCS...
16 years agoI met the error on 2C35. Maybe it works for your device. Then you may continue with this version.
- Hippo
