16 years agoBootloader for uClinux-MMU with EPCS
I'd like to load uClinux-MMU from the EPCS. The physical address for instruction memory is 0x02000000, so the only way to access it is through the TLB. The default boot copier supplied for the EPCS...
16 years agoThen this is a hardware design issue. You will have to relocate your sdram in sopc builder, to address lower than 0x20000000. I would suggest 0x10000000 for the coming fdt support. I will update the wiki on this point.
- Hippo
