Board Description Editor
I installed Quartus 5.1 SP1 and I still can not "Generate" the SOPC system after making a board description. I tried selecting the new board description, de-selecting it, selecting it again, etc... Without a board description you can not use the flash programmer IDE. The command line works, but regardless the IDE would be easier for the end-user and it *should* work!
I still get the following error - does anyone else? ................# 2006.02.01 09:06:18 (*) Running Generator Program for cpu ERROR: c:/altera/kits/nios2_51/components/altera_nios2/cpu_core_select.pl 49 CALLED (e_project::new) c:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 188 CALLED (e_project::build_new) c:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 213 CALLED (e_project::handle_args) c:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 312 CALLED (e_project::device_family) WHERE 'expected exactly one argument' OCCURRED on c:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 1315 Error: Generator program for module 'cpu' did NOT run successfully.4 Replies
I also can't use the "new board description" of sopc builder.
But command line mk_target_board is giving the following error: [SOPC Builder]$ mk_target_board --name=cpuBoard --family=cyclone --clock=50 --index=1 --epcs=U40 --buffer_size=512 Make Target Board version 1.01 Switch summary: Board name: "cpuBoard" Board class: cpuBoard Device family: Cyclone Clock frequency: 50000000hz Payload buffer size: 512 bytes EPCS flash enabled with reference designator: U40 ERROR: c:/altera/kits/nios2_51/bin/create-board.pl 1279 CALLED (main) c:/altera/kits/nios2_51/bin/create-board.pl 99 CALLED (cb_setup_directories) c:/altera/kits/nios2_51/bin/create-board.pl 511 CALLED (europa_utils::find_com ponent_dir) /cygdrive/c/altera/quartus51sp1/sopc_builder/bin/europa/europa_utils.pm 2030 CALLED (europa_utils::ensure_class_ptfs) WHERE 'get_class_ptf and ensure_class_ptfs must be called with g{system_directory}' OCCURRED on /cygdrive/c/altera/quartus51sp1/sopc_builder/bin/europa/europa_utils.pm 1923 Anyone knows what may be wrong? - Altera_Forum
Well, I have a Service Request open with Altera about this and they are aware of the problem. They are able to reproduce the errors with my project that I sent them which just has a Nios and some flash - nothing else in the FPGA.
Why they needed my project to reproduce this error, or why it was released twice with the same known bug is beyond me. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif - Altera_Forum
lemonoje, I found I can't do flash programmer with NiosII IDE5.1+SP1 even though I use the altera EP2c35 board. But I can flash programmer by using the altera EP2c35 board with NiosII IDE5.0. whether there is some bugs with NiosII IDE5.1+SP1.
I don't know why it isn't working for you but the problem i had was due to the Board Description Editor. However, the command line interface to the flash programmer works fine, except for the Verify function (unless that was repaired in 5.1 SP1).
The BDE only works if you make the Board Description/Save it, open it back up select the device family, exit the BDE, de-select it in SOPC, RE-select it in SOPC and it may generate without errors (from what they tell me).
