20 years agoBoard Description Editor
I installed Quartus 5.1 SP1 and I still can not "Generate" the SOPC system after making a board description. I tried selecting the new board description, de-selecting it, selecting it again, etc... ...
20 years agoI don't know why it isn't working for you but the problem i had was due to the Board Description Editor. However, the command line interface to the flash programmer works fine, except for the Verify function (unless that was repaired in 5.1 SP1).
The BDE only works if you make the Board Description/Save it, open it back up select the device family, exit the BDE, de-select it in SOPC, RE-select it in SOPC and it may generate without errors (from what they tell me).
