20 years ago
boa problem
# Auth: HTTP Basic authorization. Format is "Auth <Directory> <PasswdFile>".# Password file should be readable _ONLY_ by root or trusted user(s). This file# is opened before boa gives out privs.# Example: Auth /secret /var/www/secret.passwd
# Auth /internal /etc/internal.passwd
I don&#39;t want to authentication.But when I start boa use command like:# boa
it appears:Authentication password file for /cgi-bin/ not found!!
And the cgi progrm can&#39;t work. The IE says: "401 Unauthorized
Your client does not have permission to get URL /cgi-bin/cgioutput0428.cgi from this server. "
Please give me some advice!!!
my QQ: 332418170
    --- Quote Start ---
    originally posted by zzh@Apr 30 2006, 03:47 PM
    # auth: http basic authorization. format is "auth <directory> <passwdfile>".# password file should be readable _only_ by root or trusted user(s). this file# is opened before boa gives out privs.# example: auth /secret /var/www/secret.passwd
    # auth /internal /etc/internal.passwd
    i don&#39;t want to authentication.but when i start boa use command like:# boa
    it appears:authentication password file for /cgi-bin/ not found!!
    and the cgi progrm can&#39;t work. the ie says: "401 unauthorized
    your client does not have permission to get url /cgi-bin/cgioutput0428.cgi from this server. "
    please give me some advice!!!
    my qq: 332418170
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14860)
    --- quote end ---
    --- Quote End ---
    maybe you should look at www.boa.org
    and post your questions to the boa forum on sf.net .
    Or search mailing list on uClinux.org .
    hi zzh,
    for more explanation can u tell where did create the cgi-bin folder, is it in :
    /home/httpd/cgi-bin
    or in other placement ?
    Hi.
    yes cgi programs are in /home/httpd/cgi-bin/ .
    I doubt the boa server offered by NiosII IDE support the cgi.
    I download boa-0.94 and install on Fedora and it is work well.
    Who can help me ? I must get boa work or I will have bad days recently.555555555555555555555
    --- Quote Start ---
    originally posted by zzh@May 2 2006, 09:43 PM
    hi.
    i doubt the boa server offered by niosii ide support the cgi.
    i download boa-0.94 and install on fedora and it is work well.
    who can help me ? i must get boa work or i will have bad days recently.555555555555555555555
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14945)
    --- quote end ---
    --- Quote End ---
    Please check ~/uClinux-dist-test/user/cgi_generic
    hi all,
    I think the best and easiest way to add boa to your file system is, in the moment when u create it :
    see uclinux quickstart for more details
    Hi,sdhain.
    did you run boa with a cgi program successfully?
    hehe.I know how to install boa into filesystem. but it doesn&#39;t work.?
