20 years agoboa problem
# Auth: HTTP Basic authorization. Format is "Auth <Directory> <PasswdFile>".# Password file should be readable _ONLY_ by root or trusted user(s). This file# is opened before boa gives out privs.# ...
20 years ago --- Quote Start --- originally posted by zzh@Apr 30 2006, 03:47 PM # auth: http basic authorization. format is "auth <directory> <passwdfile>".# password file should be readable _only_ by root or trusted user(s). this file# is opened before boa gives out privs.# example: auth /secret /var/www/secret.passwd
# auth /internal /etc/internal.passwd
i don't want to authentication.but when i start boa use command like:# boa
it appears:authentication password file for /cgi-bin/ not found!!
and the cgi progrm can't work. the ie says: "401 unauthorized
your client does not have permission to get url /cgi-bin/cgioutput0428.cgi from this server. "
please give me some advice!!!
my qq: 332418170
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14860)
--- quote end ---
--- Quote End --- maybe you should look at www.boa.org and post your questions to the boa forum on sf.net . Or search mailing list on uClinux.org .
