16 years agoBoa configuration
When I execute boa I receive an error as: --- Quote Start --- [30/Nov/1999:00:14:38 +0000] No such user: root --- Quote End --- I have tried to configure boa but I haven't succeeded . I have changed some parameters of "etc/boa.conf", I Also have inserted some printf's in "config.c" to check if the information that is read is correct. I have noticed that information that is readed is always the same althought I have modified boa.conf. This is the correct file to change the configuration of Boa?, or which things I do wrong. PD: I have a DE2-70 with uclinux MMU Thanks a lot12 Replies
Where is the file that you are modifying?
I have found two boa.conf, and I have changed the two of them to know what happened. The first path is: /nios2-linux/uClinux-dist/romfs/etc/boa.conf The second path: /nios2-linux/uClinux-dist/romfs/home/httpd/boa.conf I have tried to change user to nobody, to try to avoid this error: --- Quote Start --- [30/Nov/1999:00:14:38 +0000] No such user: root --- Quote End --- Thanks a lot - Altera_Forum
I have a running boa (on a No-MMU installation)
in my /etc/boa there is (comment lines deleted) Port 80 User root Group root ServerName www.nios2.com (http://www.nios2.com) DocumentRoot /home/httpd UserDir public_html DirectoryIndex index.html KeepAliveMax 100 KeepAliveTimeout 20 MimeTypes /etc/mime.types DefaultType text/html ScriptAlias /cgi-bin/ /home/httpd/cgi-bin/ (www.nios2.com (http://www.nios2.com) seems to be quite irrelevant, I don't have such a thing) Moreover I do have a user ftp with no password: cat /etc/passwd root:$1$9T/VnwvK$ftljw4uPOFUdEHO.v3yh5/:0:0:root:/:/bin/sh ftp:x:500:500:FTP User:/home/ftp: and a directory /home/ftp for boa to use. -Michael - Altera_Forum
--- Quote Start --- Hi, I have found two boa.conf, and I have changed the two of them to know what happened. The first path is: /nios2-linux/uClinux-dist/romfs/etc/boa.conf The second path: /nios2-linux/uClinux-dist/romfs/home/httpd/boa.conf I have tried to change user to nobody, to try to avoid this error: Thanks a lot --- Quote End --- If you modify either of those, they will get overwritten on build. You should edit the one in your vendor directory e.g. vendors/Altera/common/boa.conf - Altera_Forum
Many thanks for answers. I have changed the parameter user to nobody, the error: --- Quote Start --- No such user:root --- Quote End --- has disappeared. Althought now has appeared another one : --- Quote Start --- [30/Nov/1999:00:00:15 +0000] ../../boa-0.94.14rc21/src/boa.c:262 (drop_privs) - getpwuid: No such file or directory child process exit abnormally.: No such file or directory --- Quote End --- I will continue searching a solution, and thanks a lot anyway - Altera_Forum
I had the same problem with you.Now I almost gave up.Maybe boa is impossible to work in Linux on DE2-70...But I wandering that if you found the solutions?
It's very unlikely that this can't work, I use boa happily on a NEEK board (with uClinux NoMMU). Hardware issues should not affect boa in any way.
Boa can work well in uClinux.So did you try some other web server in linux on DE2-70?
Well, it looks that that particular error is due to a missing /etc/passwd file?? -slacker../../boa-0.94.14rc21/src/boa.c:262 (drop_privs) - getpwuid: No such file or directory child process exit abnormally.: No such file or directory - Altera_Forum
--- Quote Start --- did you try some other web server in linux on DE2-70? --- Quote End --- I don't have a DE2-70. But as said, hardware should not matter here. -Michael
