16 years agoBoa configuration
Hi, When I execute boa I receive an error as: --- Quote Start --- [30/Nov/1999:00:14:38 +0000] No such user: root --- Quote End --- I have tried to configure boa but I...
16 years ago --- Quote Start --- Hi, I have found two boa.conf, and I have changed the two of them to know what happened. The first path is: /nios2-linux/uClinux-dist/romfs/etc/boa.conf The second path: /nios2-linux/uClinux-dist/romfs/home/httpd/boa.conf I have tried to change user to nobody, to try to avoid this error: Thanks a lot --- Quote End --- If you modify either of those, they will get overwritten on build. You should edit the one in your vendor directory e.g. vendors/Altera/common/boa.conf
