20 years agoavalon slave interface
Hi All,
I'm a new, i'm trying to make an avalon slave interface to have access to an external logic ( Fifo), i would just write, read and controls the fifo from the nios. i didn't find anythink simple in the altera litterature which explains, how to make this interface and how to get access to registers. someone can help thanks1 Reply
The document you should read is the Avalon Interface Specification
http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) and the Developing Components for SOPC Builder http://www.altera.com/literature/hb/qts/qts_qii54007.pdf (http://www.altera.com/literature/hb/qts/qts_qii54007.pdf) Those should get you started. Can't just give you the answers you know. Play around and then post some specific questions if you get stuck. Jake
